Thermo controlled vacuum switch and vacuum advance
4K views 9 replies 2 participants last post by  TxGTO69
Two sources of vacuum, ported and manifold. The engine under the 69 emissions system is tuned to operate on ported vacuum. When an overheat condition exists (230* and above) the thermo valve switches to manifold vacuum which advances the timing, increasing engine and fan speed when at idle.
The Ported vacuum source on an original 69 carb is on the middle right front of the carb, that line then connects to the middle left nipple of the thermo switch.
The Manifold vacuum source comes from the rear carb baseplate fitting that provides vacuum to the power brakes and auto trans modulator; that line connects to the lower left nipple of the switch.
The lower right nipple of the switch provides the sourced vacuum to the distributor advance.
