Verba Phonic switch wiring
1 reading
7.2K views 19 replies 10 participants last post by  Beers
#1 ·
Need a wiring diagram for the "reverb" switch on a 1968 GTO.
There are six wires connecting to the switch. It looks like 3 in and 3 out.
Right now, the front speaker works with Reverb OFF. With the switch in REVERB, both speakers work, and the reverb works. In the REAR switch position, only the rear speaker works. My understanding is the front speaker should work in any switch position.
Could be a problem in the switch, as the amplifier and reverb cut in an out as I move the switch or the wires.
#2 ·
Answering my own question
I did find a wiring diagram for that radio, and will provide it to anyone who needs it.
The reverb switch has three positions, and it turns out OFF means front speaker only, REVERB means front and rear with reverb active, and REAR means rear only.
I also made a drawing of the switch with the positions of the six wires that connect to it, and will keep that in case anyone else runs into this issue.
Dan Hinnah
#4 ·
Dan Hinnah
I’ll take a copy if u still got it ,thx! jetzster
#5 · (Edited)
One thing to note is the reverb switch’s “Center middle position-REVERB”Only puts the reverb effect on the back speaker audio,however, it should still turn on the front speaker audio , but with NO reverb effect.
Thats how you get the correct
Balance of the two sounds to create the lush echo “fake Stereo” effect, (that’s all there was avail till ‘66-67 when cooler sounding two channel FM-stereo radios came into the scene, after that the reverbs were discontinued, prob also cause the reverb amps delay-spring transponders were sensitive, and broke pretty easily from the cars bouncing effect...
Now If both speakers put out the revrb echo effect At the same time,it would be hard to understand radio people talking and you’d hear the music with too much echo going on to make sense of it...
position one-(Off) is front only-no reverb, position 3-(REAR) is rear only-no reverb, so just remember, you should never hear any reverb from the front speaker, just it’s plain sound when in pos-OFF or pos-REVERB,
And in pos-REAR you should hear only t
he rear speaker’s audio with no REVRB.
Added a hidden RediRad-AM modulator and works slick as snot, as it’s Aux input jack allows possibilities , like for you to stream all online or stored music thru a tiny inexpensive Bluetooth receiver module (that can link to any smartphone) ,and one can play CDs/& FM from a tiny portable CD-FM Unit also hidden in the glovebox.
All goes into the AM Radio
When it’s tuned to 1000khz, and then out thru the original reverb system.
So with no obvious mods on the old radio, now can Hear music from the ‘60s-70s just like it was played and heard then, (instead of nowadays Crappy AM Stations) , with the added reverb effect if desired.
It is a highly recommended unit that works well on both the Original AM and FM radios.
#6 · (Edited)
Here is a typical Delco Reverb switch and unit
After pulling out factory male connector from radio,
The new MALE black connector goes into the radio, the FEMALE connector goes into the MALE factory cable that WAS plugged into the radio.
You can see it loops-thru the radios +12v power on the BLUE wire , and also half taps the Blue +12v thru the Red connector into the switch to be used For the Reverbs power.
It also loops a solid BLACK wire for a radio ground.
The GREEN is the Original radio Front speaker output from radio ,that will now go into the switch. Switch then sends the Front speaker output audio back out on a solid BLACK to the FEMALE connector, and sends out the new Rear speakers output on the WHITE-STRIPED BLACK wire to a separate single connector.
This wire and a ground wire, need to get to the rear speaker with 2 separate at least 16 gauge wires under the floor , or it can be just one wire ,if the rear speaker has been already grounded to frame on one side, usually like the front speaker is.
(With no Reverb From the factory , the Front speaker usually is just grounded on one side to the frame, and has just a single GREEN wire going to it coming out of the radio , and there’s usually a Blue wire going into radio with keyed 12v, and usually a Black ground wire goes into radio Also)
The three combo connector red-green-black -goes to the 10’ long 3 wire pigtail jumper on the left of pic ,under the floor, back to the reverb unit now mounted in the trunk on back of rear seat ( green-input , black-output,red-12v)
Now mount switch under dash and it’s complete.see previous post for 3 position switch Settings. May need to just cut and hard-wire splice some of these wires thru if your radio has different plug connector, but it should still work..
I believe the back 6x9 speaker added should probably be a 10 ohm like the front speaker, (Ames sells them) as most auto speakers were 10 ohm at the time.In the 20% rule, an 8 ohm could work ok, but it is making the radio work harder for the same sound level, hence the newer type 4 ohm speakers would definitely be big trouble for any older original radio. If the volume sounds way down or tinny possibly you have an impedance mismatch, so it needs to be verified that the rear speaker load impedance works and transfers soundz correctly from the reverb unit and radio before all the work of installing.
A good idea would be to just tempy wire all the things together on the floor and test that everything works well first!
Ideally one can also add an aftermarket speaker enclosure around it for even better cool, one of a kind , Classic Reverb soundz!
Hope this helps..
  1. Image
#12 ·
What year is your car?
As an FYI, the 68/69 Reverb unit was mounted above the glovebox with a special bracket which was shared with the stereo multiplex unit.
The brackets are different between 68 and 69.
The switches are different.
Amplifiers were different between 64-67 and 68-69.
Reverb option discontinued in 1970
The service manual has a wire outline for all the radio options in the accessories chapter.
#13 ·
Why do the pics show it mounted below the rear speaker in the trunk?
