Mickey thompson valve covers
2 reading
1.8K views 9 replies 5 participants last post by  armyadarkness
#1 ·
do mickey thompson valve covers clear the brake booster and master cylinder in a 1970 GTO with a pontiac 400
#8 · (Edited)
Stock boosters are 11"
Stock VC's have rounded edges, so it's not enough to merely go by VC height. An aftermarket VC, of the same height, but with a square edge, will give trouble. Add poly locks to that, and forget it.
My advice to the OP, if you truly desire the aftermarket VC's, simply buy a cheap, 9" booster and swap it out. Its a fairly painless job.
#9 ·
On my 65 the MT's cleared a stock booster. I do have a summit front disc kit on - it uses later stock GM components - pretty sure the booster is 11" no issue getting valve covers on or off.
I have stock valve train with poly locks. if you are running a taller valvetrain and need to space the covers off the head you may have issues.
#10 ·
My old 67, with a stock booster, had roller rockers and polys. I tried to run plain-old-edelbrock-chrome VC's, same height, and NO Dice!
Back then, I wasnt wise enough to swap boosters, but I was definitely dumb enough to run stamped rockers on #7, while everything else had sweet anodized rollers!
