T56 gear ratio question
3.8K views 2 replies 2 participants last post by  Noangelbuddy
#1 ·
I'm restoring my 65 GTO and so far have purchased a Dana 60 3.73 posi-rear and P225/70R15 tires. For street driving, which gear ratio ( close or wide ) is better in a T56 6 speed?
The numbers look like this:
Close: 1st 2.66, 2nd 1.78, 3rd 1.30, 4th 1.00, 5th 0.80, 6th 0.63
Wide: 1st 2.97, 2nd 2.10, 3rd 1.46, 4th 1.00, 5th 0.74, 6th 0.50
Welcome your advice on which gear ratio to choose and why.
Noangelbuddy
#2 ·
Hi, I just swapped a Magnum Viper T56, 6 speed into my '65 as well. I have the close ratio you show in your post. I also have 3:08 gear in my rear end, ordered 4:10 gears to replace the 3:08's. Still waiting for the gears to come in, as they are not a stocked item for a Pontiac rear. I did drive the car one day with the 3:08's, before I put it into winter storage. The T56 was nice but the 5th and 6th shift I couldn't used because of the low rear gear. Even with that I was still able to smoke the tires. Hope this helps with your decision.
Joe.
