3.23 gear set .
8.1K views 11 replies 6 participants last post by  Fathead Racing
#1 · (Edited)
The closest gear set I can find for my stock 8.2 is 3.36. I don,t mind this to much but the speedo will not be correct. Is there any vendors that sell the correct 3.23 set? Also can I put 10"x 15" rear and 8"x 15" front cragers on the GTO. This is a 1965.
#2 ·
No help on the gears, but no on the wheels without jacking the car up high like some of the "donks" we see running around in the 'hood. A better choice would be 15X8 rears with a 4 1/2" backspace and 15X6 front with a 3 1/2 backspace. Getting the right width and aspect ratio on the tire would be the next hurdle. That's all personal preference. With those sizes you actually lower the car just wee bit around those rollers and get a really sinister stance out of the deal. Back in the day it was 10X15 mags, N50-15 belted tires (Pro-Tracs were hot) and the requisite Gabriel Hi-Jackers air shocks. Those proud of their choices always put the "hot rod" jackrabbit sticker that came with the shocks somewhere on the car too. Not all nostalgia is a good thing...(!)
#3 ·
Have you called Yukon yet? I know they have a 3.23 ring and pinion for an 8.5 10 bolt, but not sure about a 8.2 BOP. I recommend calling them for a solution.
I'm still chuckling about Mr 666bbl's straight out of the 70's tire/wheel/shock selection. I ran L60s for a while. Sorry I can't help you on the wheels. Matt
#4 ·
I've called around to find a 3.23:1 ring and pinion for the 8.2 Pontiac and have been told repeatedly that it is not being produced anymore. You may be able to find New Old Stock, or a good used set somewhere but as I understand it, that's about your only option.
#5 ·
You can NOT install a 3.23 gearset in your carrier. You will need to change the entire carrier assembly to run a 2.93-3.23 ring and pinion. The carrier you have now will accomodate the 3.36-4.33 ratios. If you want a 3.23 ratio, just bolt a set of 27.5" tall tires onto your 3.36 rear end. That's what I did with my '65 GTO.
