68 GTO Sway Bar Upgrade/Install, Performance improvement?
7.2K views 13 replies 10 participants last post by  69Goatee
#1 ·
If I upgrade front sway bar to 1 5/16" and install a 1" rear sway bar. Will I experience a significant improvement in handling? Currently the 1" front and no rear sway bar configuration still allows the car to roll significantly when turning.
Also, does anyone know what vacum pressure should be at the actuators on a hideaway headlights. I'm only getting 3.
Any and all input appreciated
Thanks,
68GOHT
#6 ·
:agree I changed out the original front springs, rears were already replaced, and shocks(they were the spiral ones) along with installing the poly bodies and the handling was night and day....
#9 ·
WARNING!! Adding bigger/better sway bars will lead to more aggressive driving and the need to install better brakes, tires,steering box, shocks and springs! I am in the middle of that right now, don't fall into that trap!:D
  • Like
Reactions: mark5775
#14 ·
:agree.. He also asked about vacuum at the hideaway actuators. I converted mine to electric motors and module from a 90's Trans Am. Unplug the vacuum supply line at the carb or manifold and hook up the gauge there, then compare it the reading at the actuators. Check all lines for cracks, then unplug all of the vacuum fittings one at a time and put a small amount of grease on them. After that, check again at the actuators to see if it matches the manifold vacuum. Might be a leaking switch or actuator, I had both.
