21 - 32 of 32 Posts
Older thread but I figured I would add my $.02.
1. 1967
2. AC -yes but Vintage Air
3. Stock rear end
4. Dropped suspension- mixed
5. Front springs are stock worn out
6. Rear springs are UMI 4950 1 inch drop
7. Front springs are of an unknown but worn out vintage. Rears are 3 months old
8. Stock front suspension
9. Stock rear control arms. Lowers are boxed in with a sway bar added
10. Fronts are 15x7. Rears are 15x8
11. Front back spacing 3.75
12. Rear back spacing 5.00
13. Front shocks are Bilstiens
14. Rear shocks are KYB
15. Front tire is 225/60/15.
16. Rear is 255/60/15
Thank you for contributing! The frequently asked questions topics are always monitored and updated!
Yes they were. The fronts are the standard 105’s and the rear are 205’s. The cheaper 105 have a standard backspacing and are a 1 piece wheel while the 205’s are 2 piece abs can be ordered in a custom backspacing. They took about 3 months to come in. Also they stress not exactly identical but you have to look closer to tell the difference. One has a chrome outer ring and the other is polished.
Quite the up charge on custom orders! Geeesh
I am embarrassed to say that ive spent more time researching wheels than i have on my wife's engagement ring.
After months of back and forth Ive settled on 17's!
I picked up American Racing VN215's--17x8 +8mm, rears and 17x7 0mm, fronts.
Tire choice is the next big obstacle! The Nitto NT555 G2 appear to be the overall winner, but i cannot decide size.
Looking for some advice. Hoping for as much aspect ratio as possible so to not look like rubber bands.
I ended up with Continental extreme contact sport 02. I won't be driving my car in snow and they supposedly have decent grip in wet weather. I don't have an close up pic of them but as far as tires go, they look good. Only drive with them for a few miles since they were out on, but handle very well and no road noise.
Very nice! Congrats!
The Firehawks handle well and are quiet enough, not that I can hear road noise over the exhaust. ;-D
Year of vehicle: 1970 GTO Hardtop
Air Conditioning: Yes VinAir under dash
OEM Rear: Yes
Dropped suspension: No
Front Springs from Ames as stock replacements, front sat low with both original and new
Rear spring manufacturer and part number: Stock replacements from Ames
Age of springs: 23 years
Front upper and lower control arms , stock
Poly grafite Bushings - Energy suspension early 2000s
Rear upper and lower control arms, make and model : stock replacements from Ames with poly grafite bushings Energy suspension
Rim size and style? Front 15x7 Outlaw 2 American racing AR625761 // Rear 15x8 Outlaw 2 American racing AR625861
Rim Offset Front -6mm // Rear -19mm // Back Space Front 3.76" // Rear 3.75"
Front shocks make and model: KYB gasadjust
Rear shocks make and model: KYB gasadjust
Front Coil Spring Spacers - 9/16
Rear Coil Spring Spacers - None
Front tire size: 215/65R15 Cooper Cobra
Rear tire size: 255/60R15 Cooper Cobra
Tested through some high speed turns, no rubbing in front, previously had rubbing issue with 15x8 with 235/60r15 .
Lok
Well, I have just ordered chrome-plated 15x10 rally 2s for the rear of my '69. I have a set of new springs for all four corners with a 1-inch lift. I plan on the 255s. The guy who had it before me had 275s on it, but it looked like the tire was going to pop off. 15x8s
21 - 32 of 32 Posts
